Best way to set a value to a variable of another plugin
I have 3 Variable on KNX pluging and I have created a custon plugin that manage a specific logic depending by some input value.
What is the best way to change value to KNX variable? some are switch type, some are valve and some are dimmer.
Thanks, Paolo
Use a Scene & add your input variable as a Trigger. Then add Actions to the Scene that update your dependent variables.
Thanks for you help!
I have used Any setting and conditions to filter.
Scene are very usefull
