Home Connect Refrigerator plugin
The following is a plugin for Bosch, Siemens and Neff refrigerators. It uses the appliance “haid” as HR “Id”. To use it, you need to create a project in the developer.home-connect.com web using Authorization Code Grant Flow. You need to create a “refresh_token” and put it in the “DefaultSettings” jointly with the “client_secret” code to generate an “access_token” every time the HR App is called. This way all the appliances of the device source will use that token.
The graphical design of the details template, as well as the icons, is based on the HC Android App.
The plugin might also be used to create plugins for other HC appliances.
If you have some comments and/or suggestions, please tell me.
HomeConnectRefrigeratorTile.xaml (3.1 KB) HomeConnectRefrigerator.plugin (8.4 KB) HomeConnectRefrigeratorDetails.xaml (19.3 KB)
HCvacationMode HCecoMode HCfreshMode HClettuce HCrefrigerator HCsabbathMode HCsnowflake HCthermometer
