Irule old timers
I am trying to export in HR the IR codes of an old device that I was using with irule a couple of years ago.
The irule forum is dead but I was wondering if one of you remembers if it is possible to export the irule devices IR codes?
I used to be an old iRule user, as well. I’m not familiar with a way to export the IR codes from devices from within iRule, but you can likely find IR codes for your device(s) on the Global Cache’s Control Tower IR database. You can download one command at a time, or all of the commands for an object if you’re a verified user (it takes a day or two to be verified). You can find the website here:
https://irdb.globalcache.com/
