*** All changes through 09/29/21 are included in the hrp’s attached to this post ***
OpenWeatherMap plugin built as a replacement for the DarkSky plugin. It will work out of the box with a few notes:
Get your free API Key here: How to start to work with Openweather API - OpenWeatherMap
Alerts do not work
Items not available:
current precipitation rate
current precipitation probability
current precipitation type
current wind gust
daily precipitation rate
daily precipitation type
daily wind gust
The WeatherIcon attribute should now be used as a web image
There is an additional attribute “WeatherId” that will return a 3 digit code for various weather conditions. You can use this if you want to use your own icons. You can see the codes here: Weather Conditions - OpenWeatherMap
Fahrenheit: openweathermap_weatheridfix.plugin (8.9 KB)
Celsius: openweathermap_weatheridfix_metric.plugin (8.9 KB)
