Hi Jiří,
Thank you for testing R5 and for the additional information!
The fact that your temperature sensor is a BLE device connected through a hub is very useful.
I can see from your previous R4 log that the Tuya API successfully returns temperature, humidity, and battery values for your sensor.
However, these values do not seem to reach the corresponding THR attributes.
The missing THR DEVICE SYNCHRONIZATION START section is also interesting. It may simply mean that the log was captured before device synchronization completed.
Could you please check one thing?
After starting THR with R5, does your temperature sensor appear in the THR Devices list with its attributes, including DP_temp_current ?
If it does, please let me know whether the attribute has a value in the device properties, or whether it is empty there as well.
This will help us distinguish between a device synchronization issue and a sensor value mapping issue.
No need to upload another full log at this stage.
Thanks again!
Best regards,
Kalle
