Problem With Button Events
Sorry…the device in Vera is virtual switch, yes.
OK just trying to understand your setup and what you are wanting to do.
So you have two Vera scenes as well.
“TvOnBedroom” scene that is triggered and run when the “TVBedroom” virtual switch is turned on.
and
“TvOffBedroom” scene that is triggered and run when the “TVBedroom” virtual switch is turned off.
What would be expected behaviour.
If you run the scene directly from HR or even in Vera, the virtual switch would not change state.
So why can’t you use the “TVBedroom” virtual switch in HR ?
Sorry I’ve not read the entire thread yet.
I explained the weird behavior at the top. If you can give it a read and see if you can help, that would be great.
I’m not really following your description.
I just had a look at the project you posted and that image button looks to be setup correctly.
So what isn’t working for you ?
If found it…there was an error in a LUA script on the Vera side for the scenes. Thanks for looking at it for me.
I see well that wouldn’t help you.
So your all sorted now and fully working ?
Yes, I am. Thank all of you for your help. I’m learning something new about HR integration every day.
