Designer crashing
I do not think I’m doing anything crazy but when trying to load the designer it’s cashing. I have attached my test file
SavantTEST.hrp (3.8 MB)
You have a bad Resources.xaml file. You added a SolidColorBrush to it but never assigned it a Key or a Color. Look at the last item in your file:
<?xml version="1.0" encoding="utf-8"?>
<ResourceDictionary xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:hr="http://schemas.thehomeremote.com/winfx/2015/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation">
	<SolidColorBrush x:Key="AccentBrush" Color="{ThemeResource AccentColor}" Opacity="1" />
	<SolidColorBrush x:Key="AccentBrush9" Color="{ThemeResource AccentColor}" Opacity="0.9" />
	<SolidColorBrush x:Key="AccentBrush4" Color="{ThemeResource AccentColor}" Opacity="0.4" />
	<SolidColorBrush x:Key="BackgroundBrush" Color="{ThemeResource BackgroundColor}" Opacity="1" />
	<SolidColorBrush x:Key="ForegroundBrush" Color="{ThemeResource ForegroundColor}" Opacity="1" />
	<SolidColorBrush x:Key="ForegroundBrush2" Color="{ThemeResource ForegroundColor}" Opacity="0.2" />
	<SolidColorBrush x:Key="ForegroundBrush4" Color="{ThemeResource ForegroundColor}" Opacity="0.4" />
	<SolidColorBrush x:Key="ForegroundBrush6" Color="{ThemeResource ForegroundColor}" Opacity="0.6" />
	<SolidColorBrush x:Key="BackgroundBrush2" Color="{ThemeResource BackgroundColor}" Opacity="0.2" />
	<SolidColorBrush x:Key="BackgroundBrush5" Color="{ThemeResource BackgroundColor}" Opacity="0.5" />
	<SolidColorBrush x:Key="BackgroundBrush7" Color="{ThemeResource BackgroundColor}" Opacity="0.7" />
	<SolidColorBrush x:Key="BackgroundBrush9" Color="{ThemeResource BackgroundColor}" Opacity="0.9" />
	<SolidColorBrush x:Key="TileBackgroundBrush" Color="#333333" Opacity="1" />
	<SolidColorBrush Color="" Opacity="0" />
</ResourceDictionary>
how can I open the file to change this? Home remote will not even open
The HRP is just a ZIP file renamed. You can unzip the archive & edit the file with any text editor. Also check your email. I sent you the fixed the file a little bit ago.
Thank you Bill. All your help thus far has been really great.
