"Error controlling device" when HS3 dimmer dragged to maximum setting
Hi Bill,
The following error message is displayed when immediately dragging a dimmer slider to it’s maximum setting:
“Error, controlling device, value not found”`
The underlying device is a homeseer lamp. The device responds by turning on but at a very low dimmer level. If I drag it down just a tad, the lamp goes to the correct higher level and no error is displayed. Also in all other scenarios the device responds as expected.
This happens both for the IOS and the PC version of my app. I am running a very recent version of HS3, but I also noticed this under older versions.
Just wondering if there is a way around this?
Dennis
You probably need to customize the range on the Slider. The default is 0 to 100. Try setting the Maximum to 99.
