Hi Bill,
Below a sample of the JSON just before the list of ‘actions’ you can see the values:
“value”:“42”,“value2”:“50”
It’s not clear to me why it’s not displaying.
By way of a little more detail:
Starting with the SwitchLevel Capability assigned to the WindowShade. If I use the corresponding @Device.Level as the Device Binding for a Slider Value the slider value is correct upon load and happily set the value when the slider is moved.
If I then include ‘value’ (the primary open/close position of the blind rather than Slat position which relates to ‘value2’) and change the Device Binding for the Slider Value to @Device.value upon load the slider doesn’t display a value but function ok once you change the slider value. In short it too doesn’t seem to read the value on load. So I observe the behaviour for both ‘value’ and ‘value2’.
{“id”:147,“name”:“Study Blind”,“roomID”:14,“type”:“com.fibaro.FGRM222”,“baseType”:“com.fibaro.FGR”,“enabled”:true,“visible”:true,“isPlugin”:false,“parentId”:146,“remoteGatewayId”:0,“interfaces”:[“deviceGrouping”,“energy”,“levelChange”,“power”,“zwave”,“zwaveMultiChannelAssociation”,“zwaveProtection”,“zwaveSceneActivation”],“properties”:{“parameters”:[{“id”:3,“lastReportedValue”:1,“lastSetValue”:1,“size”:1,“value”:1},{“id”:10,“lastReportedValue”:2,“lastSetValue”:2,“size”:1,“value”:2},{“id”:12,“lastReportedValue”:100,“lastSetValue”:100,“size”:2,“value”:100},{“id”:13,“lastReportedValue”:1,“lastSetValue”:1,“size”:1,“value”:1},{“id”:17,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:18,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:22,“lastReportedValue”:240,“lastSetValue”:240,“size”:2,“value”:240},{“id”:29,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:30,“lastReportedValue”:2,“lastSetValue”:2,“size”:1,“value”:2},{“id”:31,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:32,“lastReportedValue”:1,“lastSetValue”:1,“size”:1,“value”:1},{“id”:33,“lastReportedValue”:1,“lastSetValue”:1,“size”:1,“value”:1},{“id”:35,“lastReportedValue”:1,“lastSetValue”:1,“size”:1,“value”:1},{“id”:40,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:42,“lastReportedValue”:3600,“lastSetValue”:3600,“size”:2,“value”:3600},{“id”:43,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:44,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:50,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:14,“lastReportedValue”:2,“lastSetValue”:2,“size”:1,“value”:2}],“pollingTimeSec”:0,“zwaveCompany”:“Fibargroup”,“zwaveInfo”:“3,3,52”,“zwaveVersion”:“25.25”,“RFProtectionState”:“0”,“RFProtectionSupport”:“3”,“categories”:"[“blinds”]",“configured”:true,“dead”:“false”,“deadReason”:"",“deviceControlType”:“55”,“deviceGroup”:"[]",“deviceGroupMaster”:“0”,“deviceIcon”:“87”,“emailNotificationID”:“0”,“emailNotificationType”:“0”,“endPointId”:“0”,“energy”:“0.35”,“localProtectionState”:“0”,“localProtectionSupport”:“5”,“log”:"",“logTemp”:"",“manufacturer”:"",“markAsDead”:“true”,“model”:"",“nodeId”:“32”,“parametersTemplate”:“721”,“power”:“0.00”,“productInfo”:“1,15,3,2,48,0,25,25”,“protectionExclusiveControl”:“0”,“protectionExclusiveControlSupport”:“false”,“protectionState”:“0”,“protectionTimeout”:“0”,“protectionTimeoutSupport”:“false”,“pushNotificationID”:“0”,“pushNotificationType”:“0”,“remoteGatewayId”:“0”,“saveLogs”:“true”,“sceneActivation”:“0”,“serialNumber”:"",“showEnergy”:“true”,“smsNotificationID”:“0”,“smsNotificationType”:“0”,“state”:“Unknown”,“useTemplate”:“true”,“userDescription”:"",“value”:“42”,“value2”:“50”},“actions”:{“close”:0,“open”:0,“reconfigure”:0,“reset”:0,“sceneActivationSet”:0,“setValue”:1,“setValue2”:1,“startLevelDecrease”:0,“startLevelIncrease”:0,“stop”:0,“stopLevelChange”:0},“created”:1626123921,“modified”:1626123921,“sortOrder”:41}
