hi Bill
I’m using a smart implant inputs for pressure measurement analog 0-10v . The outputs as switches
inputs and outputs are disconnected in the HC3
i can see the outputs in the HR but not the analog inputs. if i set the smart implant to binary inputs i can see it in the HR . I had a similar problem before and you sorted it out in a updated HR version
can you take a look at it see API
thanks
tony
{“id”:779,“name”:“Heating pressure”,“roomID”:219,“view”:[],“type”:“com.fibaro.zwaveDevice”,“baseType”:“com.fibaro.device”,“enabled”:true,“visible”:false,“isPlugin”:false,“parentId”:1,“viewXml”:false,“configXml”:false,“interfaces”:[“polling”,“zwave”,“zwaveAssociation”,“zwaveConfiguration”,“zwaveMultiChannelAssociation”,“zwaveSlaveRouting”],“properties”:{“associations”:[{“endPointId”:0,“groups”:[{“groupInfo”:{“commands”:[{“command”:“Device Reset Locally Notification”,“commandClass”:“Command Class Device Reset Locally”},{“command”:“Notification Report”,“commandClass”:“Command Class Notification”},{“command”:“Central Scene Notification”,“commandClass”:“Command Class Central Scene”}],“name”:“Lifeline”,“profile”:“General: Lifeline”},“id”:1,“multiChannel”:{“bitAddressable”:false,“max”:1,“set”:[{“endPointId”:[0],“nodeId”:1}],“view”:[{“endPointId”:[0],“nodeId”:1}]},“singleChannel”:{“max”:1,“set”:[],“view”:[]}},{“groupInfo”:{“commands”:[{“command”:“Basic Set”,“commandClass”:“Command Class Basic”}],“name”:“On/Off (IN1)”,“profile”:“Control: Control Key 1”},“id”:2,“multiChannel”:{“bitAddressable”:false,“max”:5,“set”:[],“view”:[]},“singleChannel”:{“max”:5,“set”:[],“view”:[]}},{“groupInfo”:{“commands”:[{“command”:“Basic Set”,“commandClass”:“Command Class Basic”}],“name”:“On/Off (IN2)”,“profile”:“Control: Control Key 2”},“id”:3,“multiChannel”:{“bitAddressable”:false,“max”:5,“set”:[],“view”:[]},“singleChannel”:{“max”:5,“set”:[],“view”:[]}}]}],“categories”:[“other”],“configured”:true,“dead”:false,“deadReason”:"",“deviceControlType”:0,“deviceIcon”:28,“deviceSpecificData”:“h’000000000000ac90”,“deviceSpecificIdType”:“Serial Number”,“deviceState”:“Configured”,“endPointId”:0,“lastWorkingRoute”:[1],“lastWorkingRouteRequestStatus”:“ok”,“lastWorkingRouteRequestTimestamp”:0,“lastWorkingRouteResponseTimestamp”:1635348076,“log”:"",“logTemp”:"",“manufacturer”:"",“markAsDead”:true,“model”:"",“neighborList”:[1,42,279,85,114,148,153,281,209,218,233,264,327,364,367,405,417,629,641,654,668,680,715,725,764],“neighborListRequestStatus”:“ok”,“neighborListRequestTimestamp”:0,“neighborListResponseTimestamp”:1635348076,“nodeId”:86,“parameters”:[{“id”:24,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:25,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:40,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:41,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:47,“lastReportedValue”:255,“lastSetValue”:255,“size”:2,“value”:255},{“id”:49,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:52,“lastReportedValue”:255,“lastSetValue”:255,“size”:2,“value”:255},{“id”:54,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:63,“lastReportedValue”:5,“lastSetValue”:5,“size”:1,“value”:5},{“id”:64,“lastReportedValue”:60,“lastSetValue”:60,“size”:2,“value”:60},{“id”:65,“lastReportedValue”:5,“lastSetValue”:5,“size”:2,“value”:5},{“id”:66,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:67,“lastReportedValue”:5,“lastSetValue”:5,“size”:2,“value”:5},{“id”:68,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:150,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:151,“lastReportedValue”:10,“lastSetValue”:10,“size”:1,“value”:10},{“id”:152,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:153,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:154,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:155,“lastReportedValue”:0,“lastSetValue”:0,“size”:1,“value”:0},{“id”:156,“lastReportedValue”:107,“lastSetValue”:107,“size”:2,“value”:107},{“id”:157,“lastReportedValue”:0,“lastSetValue”:0,“size”:2,“value”:0},{“id”:20,“lastReportedValue”:4,“lastSetValue”:4,“size”:1,“value”:4},{“id”:21,“lastReportedValue”:4,“lastSetValue”:4,“size”:1,“value”:4}],“parametersTemplate”:825,“pollingInterval”:-1,“pollingTimeSec”:0,“productInfo”:“1,15,5,2,16,0,5,1”,“saveLogs”:true,“securityLevel”:"",“securitySchemes”:[],“serialNumber”:“h’000000000000ac90”,“useTemplate”:true,“userDescription”:"",“zwaveCompany”:“Fibargroup”,“zwaveInfo”:“3,6,2”,“zwaveSoftwareVersion”:{},“zwaveVersion”:“5.1”},“actions”:{“getLastWorkingRoute”:0,“getNeighborList”:0,“getParameter”:1,“poll”:0,“reconfigure”:0,“requestNodeNeighborUpdate”:0,“setParameter”:2},“created”:1635348075,“modified”:1635348075,“sortOrder”:313}
