Hi Bill,
Is it possible to do this via a script in a trigger, rather than use a plugin? I want to animate a grid in steps up the page by altering a margin. I remember someone demoing this previously but cant find it in the forum.
John
Hi Bill,
John
Yes. The Margin property can be changed with a trigger or script. It’s a comma separated string, just like it is in the Properties pane. “0,0,0,0” has no margin.
Thanks Bill… how do i call it in the script…
Example : App.SetProperty.Margin(0,0,0,0)
I usually recommend using triggers instead of a script. If you must use a script, here’s how to do it:
YourImageControlName.Margin = "0,0,0,0"
I will use multiple triggers interleaved with delays if that is a better way.
