Hi, has anyone written or come across a plug-in to connect THR to an APC network connected device power device? They have telnet/ssh/snmp capabilities so hoping someone has already done this.
Example unit:
Thanks in advance!
Example unit:
Thanks in advance!
use TCPClient
for example
plugin.Name = "UPSPlugin";
plugin.PollingInterval = 0;
plugin.DefaultSettings = { "Host": "192.168.1.11", "Port": "3551" };
var tcp = new TCPClient();
var tcpDeviceId = "apcupsd";
then send status command
while (true) {
tcp.send([0x00, 0x06, 0x73, 0x74, 0x61, 0x74, 0x75, 0x73]);
var data = tcp.receive();
console.log("message received" + data);
and wow
just parse response as string
i hope that’s can help you!
Great, thanks. I’ve taken what you’ve got and started applying it to the device I have which is a power strip. Getting there and will send you what I end up with.
Thanks!
