Apple TV Plugins
Hi… Everyone
Is it possible to control Apple TV without Global Cache or Broadlink?
Thank you
No, not directly from THR, but for IP control you could use something like Home Assistant. THR has a Home Assistant integration.
I see their integration is open sourced; I wonder how much effort it would be to integrate with THR - I’d be willing to kick in some money to support a proper integration as while Global Caché and an IR sensor does work, a native IP solution would probably be more robust - especially if it would allow for direct launching of specific apps (as is possible with the Roku).
You would have to convert Python into JavaScript.
Perhaps https://github.com/evandcoleman/node-appletv would be a better solution, then.
