I’m a new THR user creating a setup for my home audio/security/lighting.
My audio distribution uses an Audio Authority HLX, an older A/V matrix switch which uses Telnet. I’ve written a plugin for it which works for switching zones/sources and muting and unmuting – anything where I can send a discrete command for each zone.
My question is about using Home Remote “slider” controls for the volume controls for each of the 6 audio zones I’m using within the Audio Authority HLX. From the available documentation I don’t see any way to pass both the current/live slider value and the audio zone number through to the HLX, unless I use separate plugins for each of the volume controls for the 6 zones.
Is this correct or am I way off?
Thanks,
Paul
