I downloaded the designer and logged into my HC3L with no issues, although on the app (I purchased the Pro version) when I try to add the devices I get - Invalid URl: The hostname could not be parsed.
Although if I create something in the designer and then open it with the app it works, as I’m new to the software I would like to have it import everything natively and then create as I go.
Also, is there any way to revert back to how the app was when first installed other than uninstalling and re installing. I deleted the devices and groups but it would still behave as if it had file loaded.
Edit - The issue is on a Samsung galaxy S20+. I downloaded and tried on an ipad as well and it worked without a problem.
