Is there a command to enable night mode on a sonos ARC? that is the only command I need implemented in order to not have to open the sonos app from THR.
Hi there, unfortunatelly I don’t know the answer, but maybe you can help me.
I am not able to find, how can I select a certain track or playlist through a command on SONOS…
So not like using buttons in HR UI, but from a scene, or by a plugin…
I want to set up a plugin or a scene which will play a certain track or playlist upon a button press or a scene run…
I would appreciate any help
There is not a command you can use to enable Night mode on Sonos.
