Add commFailure attribute as default to Vera devices.
I have a dashboard which shows door contact sensor statuses i.e. whether door is open or closed. One door showed nicely closed all the time even in Vera that sensor was marked “Can’t detect device”. Rootcause for issues was empty battery in the sensor. So behaviour here is that contact status will stuck to a value even sensor cannot be reached and that is not good for making status display. There is however attribute “commFailure” which tells is the device connection OK.
