If you see the attached video, when I am filling in the path for a multibinding, it will then remove paths from many multibindings. See the 3 blue label fields that I create, then have disappeared at the end.
It seems that typing in the filter is for some reason causing this. I was able to replicate it myself. For the time being, you’ll probably have to avoid using the filter & scroll through the entire list. Or you can edit the XAML directly. I’m looking into it now. I will try to get this fixed in the next release.
Edit: I have fixed this on my development machine. It will definitely be part of the next release.
Excellent news! I have run into this a number of times myself, but hadn’t reported it yet.
