Hi
So I have been struggling with getting started with The Home Remote. What I have found is just to get to the point where you can drop controls on the page requires so many complicated non-clear steps that using this application is impossible. I watched as many videos as I could and found that they go on and on and on - literally for over an hour. Video documentation shouldn’t be the only resource - and if it is then it should be to the point and concise. I used The Home Remote several years ago - I seem to remember it being easier to use. I am really looking for some concise documentation on getting started. So currently, I have a page called LoftMain.xaml. I click “Menu Item” to add something to the page - because all of the controls are grayed out and for some reason it wants to add another page. I don’t want to add another page. I just want to add controls to the page I am on. I tried setting up the remote on my iPhone, exporting the page, and loading it in the designer. What I found is that the remote is now built with little tiles - I don’t want tiles. I want a page of buttons. Why is this application so complicated? I understand with flexibility comes complication - however, if the first hump of using an application is so complicated and you can’t figure out how to get started then there is a major problem. So this post is a bit of venting and also a call for help.
