Hi, I currently use home assistant to access some devices that do not have native home remote integrations. I also use a number of input Boolean values in Home Assistant to track device status across multiple remotes.
I’ve loaded up a project that has been in use for a around a year and working fine, where things get strange is that I’ve loaded it onto a new laptop to make some changes and everything works until I run synchronise devices in the designer. As soon as I do this device states will not synchronise and when trying to set anything from the project running on designer or the app I receive an error which states “Input string was not in a correct format” however nothing has been changed in the project?
Has anyone else experienced this behaviour and has any suggestions?
