Hi guys,
I am looking to display the current status icon of a Homeseer virtual device such that the icon updates based on the value of the device. To do this I setup a virtual device in HS e.g. “current_conditions” who’s value can be set to e.g. 1 = sunny and 2 = cloudy.
After setting up this device, uploading and linking 2 icons representing the 2 status’es in HS, and then syncing designer, the property “current_conditions.icon” now appears in the icon Device Binding dropdown, however no image displays when switching the value back and forth in HS.
If I add the same icon png’s directly in the designer, they display correctly.
I am aware that I could add some triggers etc. based on the device’s value property to change the icon, however I would prefer to simply set the icons in HS and just display the icon representing the current value in THR.
Is there a way to achieve this?
Dennis
