HI, I’m using Homeseer and read a post from last year where someone was asking about how Homeseer devices are named. It confirmed what I thought which is that it’s not a single simple algorithm.
The problem I’m running into is that I created a set of virtual devices in Homeseer that get populated with current energy use on each circuit in my house - so there are around 20 virtual devices. Each virtual device has 2 features to store the actual power consumption in Watts and the apparent power in VA. The sync creates devices for each feature with names like Power, Power1, Power2, … Power19 and VA, VA1, VA2, … VA19 - so I have no idea which circuit they relate to unless I go through and look at the associated device ids and rename all of them manually.
Is there anything I can do on the HomeSeer side to force the sync to use some other piece of data from HomeSeer like the address or code field when naming these so I can have some control over the names?
