how can i overlay the image
Not enough information
excuse me. I need to make an overlay so when I click on an image button it changes the image from on to off
Ok I understood something different from the subject.
In simplistic terms, you can create a button that’s a toggle behaviour, and use the checked/unchecked events as triggers, and the setter can be the IsVisible property of the image control. I can put an example together for you if needed.
EDIT: nothing fancy but should show you how
test for pedrozancan.hrp (340.1 KB)
