Is it possible to change an image based on the status of 2 different devices? This is the situation: I have a fan with 3 capacities ‘low’, ‘mid’, and ‘high’. These capacities are selected by using a Fibaro double switch: both switches off = low, 1 switch on and 1 switch off = mid and both switches on = high, depending on the CO2 level in the room. I want to visualise the actual capacity of the fan by showing an image of a fan with different speeds and depending on the status of the 2 devices. With 1 device I can create a tile and assign the related device to it, but how can I use 2 different devices?
For this I need three images like:
