Hello, I synced a Zlink Water and Temperature Sensor from Hubitat to Home Remote and it shows the battery level and wet/dry state, but temperature is missing. I thought temperature was a standard capability that would appear on the Home Remote dashboard? Is there something I’m doing wrong? Here is relevant info and capabilities JSON from the Maker API:
{“id”:“52”,“name”:“Zlink Water Leak and Temperature Sensor”,“label”:“Crawlspace and Mechanical Room”,“attributes”:[{“name”:“battery”,“currentValue”:100,“dataType”:“NUMBER”},{“name”:“temperature”,“currentValue”:50.0,“dataType”:“NUMBER”},{“name”:“water”,“currentValue”:“dry”,“dataType”:“ENUM”,“values”:[“wet”,“dry”]}],“capabilities”:[“WaterSensor”,{“attributes”:[{“name”:“water”,“dataType”:null}]},“Configuration”,“Battery”,{“attributes”:[{“name”:“battery”,“dataType”:null}]},“TemperatureMeasurement”,{“attributes”:[{“name”:“temperature”,“dataType”:null}]},“Sensor”],“commands”:[“configure”]}
[{“capabilities”:[“WaterSensor”,{“attributes”:[{“name”:“water”,“currentValue”:“dry”,“dataType”:“ENUM”,“values”:[“wet”,“dry”]}]},“Configuration”,“Battery”,{“attributes”:[{“name”:“battery”,“currentValue”:“100”,“dataType”:“NUMBER”,“values”:null}]},“TemperatureMeasurement”,{“attributes”:[{“name”:“temperature”,“currentValue”:“50.0”,“dataType”:“NUMBER”,“values”:null}]},“Sensor”]}]
