Hi Bill,
My HR configuration with Hubitat works well, but it takes long time to load devices everytime app starting, around 8s , respond time of Hubitat device is longer than other as Home assistant as well. I guest reason is about polling time , if I am right, how can I adjust this parameter. Otherwise, please advise!
Thank you
Is this at home or when you are away? When you are at home it should use a WebSocket if properly configured so you should receive responses very quickly. When away, it does have to use polling so it’s not going to be as fast. Although 8 seconds sounds long though even for that. I suppose if you have a lot of devices to poll it could take a while. 1st thing though, make sure local access is working. As a fallback it will use cloud access if it for whatever reason it cannot connect locally. Try unchecking the Enable Cloud Access option & make sure you have the correct IP Address entered.
