Ip Camera Selecting Channel
How do I select the channel when connecting to NVR? I am able to connect to channel 1 but not any of the others.
Also is it possible to make the tiles larger?
I currently do all my setup in the android app. I’m willing to buy the developer app if needed.
You will need to add a separate device for each channel. The channel number is usually a query string parameter on the URL. I don’t know exactly how this will be applied for your system. I generally refer people to this iSpyConnect website below. They’ve got a pretty big database of most camera URLs. It should show you how to specify the channel.
https://www.ispyconnect.com/sources.aspx
Thanks for the quick response. I spy object confirmed I have the right setup. The problem seems to be The Home Remote app is only able to display one camera at a time. If I click into the blank image, all cameras displays individually in full screen. I am unable to view all cameras in the group tab simultaneously.
Any idea why this would be.
I do not know. I have never worked with that system. They may only allow 1 connection at a time.
What is the make & model number for the system?
What type of streams are these? HTTP, RTSP, MJPEG, JPEG?
If you aren’t already doing so, see if they have this system supports JPEG snapshots (most do). You’ll be less likely to run into any connection limits when using HTTP snapshot URLs.
Can I anyone help me setting up TP Link NC 450 Camera? I have 4.
Try this URL=>
rtsp://user:password@IP_ADDRESS/h264_hd.sdp
I found that on the iSpyConnect website.
https://www.ispyconnect.com/man.aspx?n=tp-link
