Would I be able to use something like this with home remote If I am unable to use a web IP solution for remotes to work with. If not could you point me in a direction for what is needed hardware for IR Remote integration with home remote
https://www.amazon.com/Conditioner-Compatible-Automation-Intelligent-Controller/dp/B07JG57NPS
For IR control I recommend using either Global Cache products or Logitech Harmony. Like I said in a post yesterday, try to stay away from the GC-100. Any of the newer Global Cache products will work fine. iTach, Flex, & Global Connect all work great.
I’m not sure if the Amazon product you found will work or not. It definitely won’t work out of the box anyway. You’d need to write your own plugin. I’d say try to stick with Harmony or Global Cache.
Thanks I can barely write the interface. Not ready to even look at plugin writing. lol
