Has anybody tried an irrigation system integration in HR? My garden is not very big, only 4 areas with 4-5 sprinklers each area. I also have a water tank that I need to control the water level for the irrigation system and install a water pump for irrigation. Finally, I would like to use a humidity sensor or rain sensor to stop irrigation. The current is 220V. What system would you recommend?
Greg, Thanks a lot for your reply! I have contacted the technicians and they will send me a quote for the water level amd moisture sensors and their hub. Did you have a look to their API? Did you write a plugin for HR? Do you know whether it exists one? It does not look very complicated though…
Many thanks again!
You are very welcome, I’m excited to see what you do with it. I haven’t looked into the documentation yet, I haven’t written a plugin and I am not aware that one exists. From my knowledge, this is a very small company. Good luck and please show us what you make with it!
Greg, I am still waiting for some information about other sensors, but their API Update Api - VegeCloud seems very easy to use and the Shelly relays, specially the new generation ones, support scripting and web hooks, so after some wotk the system might work quite well and very nicely integrated in Home Remote ! The thing is that they do not have distributors, so I will have to buy directly to them in the US and it might take some time to get the devices here in Spain… I will let you know what I finally do…
Greg, I just bought the water level and moisture sensors with the hub. It might take while until I get them in Spain. Then, I will have to write a plugin for HR and implement webhooks for the Shelly relays. I will let you know about my progress
Thanks a lot for the information!
Yes, please do! It has gotten me thinking about other ideas for my yard and garden.
