Attached is a Plugin for JRiver Media Center.
https://jriver.com
To install the plugin, use the Plugin Import utility in the Designer. The import process will ask you for the Host (IP Address) of the server running JRiver.
Here is the plugin code:
JRiverMediaCenter.plugin (2.4 KB)
plugin.Name = "JRiverMediaCenter";
plugin.PollingInterval = -1;
plugin.DefaultSettings = { "Host": "192.168.1.100" };
var http = new HTTPClient();
var baseUrl;
var commands = {
"Play": "Playback/PlayPause?Zone=-1&ZoneType=ID",
"Pause": "Playback/PlayPause?Zone=-1&ZoneType=ID",
"Stop": "Playback/Stop?Zone=-1&ZoneType=ID",
"SkipForward": "Playback/Next?Zone=-1&ZoneType=ID",
"SkipBackward": "Playback/Previous?Zone=-1&ZoneType=ID",
"DirectionUp": "Control/Key?Key=Up",
"DirectionRight": "Control/Key?Key=Right",
"DirectionDown": "Control/Key?Key=Down",
"DirectionLeft": "Control/Key?Key=Left",
"Select": "Control/Key?Key=Enter",
"PageUp": "Control/Key?Key=Page%20Up",
"PageDown": "Control/Key?Key=Page%20Down",
"Back": "Control/Key?Key=Backspace",
"Space": "Control/Key?Key=Space",
"DisplayToggle": "Control/MCC?Command=10012",
"ShuffleOn": "Control/MCC?Command=10005&Parameter=4",
"ShuffleOff": "Control/MCC?Command=10005&Parameter=3",
"PowerOff": "Control/MCC?Command=27001,0",
"FastForward": "Control/MCC?Command=10008&Parameter=10",
"Rewind": "Control/MCC?Command=10009&Parameter=10",
"Audio": "Control/MCC?Command=22001&Parameter=3",
"Video": "Control/MCC?Command=22001&Parameter=5",
"Images": "Control/MCC?Command=22001&Parameter=4",
"Home": "Control/MCC?Command=22001&Parameter=1",
if (attribute != "MediaCommand")
throw "Invalid attribute";
var command = commands[value];
if (!command)
throw "Invalid command";
http.get(baseUrl + command);
baseUrl = "http://" + plugin.Settings["Host"] + ":52199/MCWS/v1/";
var mediaCenter = plugin.Devices["1"];
if (mediaCenter != null) {
mediaCenter.SupportedMediaCommands = Object.keys(commands);
function onDisconnect() {
var mediaCenter = new Device();
mediaCenter.Id = "1";
mediaCenter.DisplayName = "JRiver Media Center";
mediaCenter.Capabilities = ["MediaControl"];
mediaCenter.Attributes = [];
plugin.Devices[mediaCenter.Id] = mediaCenter;
