Linear GoControl Garage door opener issues
I did not have a chance to test using Both .Switch and .Contact. I did try .Contact on the Button with Open and Closed but got Toast error (400) as reported earlier in Thread. I Will try to capture raw sdata per your suggestion. I will need some time with it, my workday is picking up.
I filtered that raw data you messaged me to only include the info for the garage device (id=505). If you look at these files, they are identical. It appears they are not including the status. I’m not sure why that is.
JSON_Open.txt (283 Bytes) JSON_Open.txt (283 Bytes)
Is there a command to pick up only device 505? Wlll try again.
Is it possible status is not part of short data?
Maybe. I don’t know what it is though.
It’s possible. You can check the service files for that device. You should be able to find out by looking at those.
Bill I used the command
http://ip_address:3480/data_request?id=user_data&output_format=xml
I think this is long data. See attached and open with notepadd++. I highlighted the line difference I found between open and closed…
505.txt (8.3 KB)
The Home Remote does not poll that endpoint. It polls sdata. Check the service files that device is using. I think you can update them.
Bill,
I resolved this by using a virtual switch on the vera hub. Basically, the virtual switch mirrors the status and activates the garage opener and vice versa. The virtual switch is supported in Home Remote so I just linked all the HR elements to that.
I reviewed the difference & the open/close status is being sent through SwitchPower1 ā€œStatusā€. This is what Home Remote was originally using. It was looking at the shortcode which is ā€œstatusā€. I’m probably going to undo that last change I made to look at the ā€œtrippedā€ variable & to again look at the ā€œstatusā€ shortcode.
If the ā€œstatusā€ shortcode doesn’t exist, then users can add a virtual switch like you are doing. I’m still a little uncertain why it’s doing that. I’m not sure why it is behaving differently than per say a light bulb that is also using SwitchPower1 ā€œStatusā€.
I am not sure either but I have some non dimable light switchs that went south as well when you switched to sdata. i also control those with virtual switches.No worries, they still work with the workaround.
