Hello.
I have been trying for several days watching videos and searching the forum for help, but I cannot work this out and need help
I have added the Harmony Remote to the Android App and added the devices. I did an export to gDrive to transfer to the designer on my PC. It creates a ZIP but I realised that if I change the ZIP to HRP I can open it.
Unfortunately it doesn’t open in a grid, with all the layout, buttons triggrs etc. Its added as a device under Groups. When you edit it, its a diagloue showng whats referenced.
So I tried to design a remote from scratch based on the media control detail xaml, but with the harmony hub it controls the signals based on the device or activity selected.
Is there a system variable that holds the device name so that when I create a trigger I reference the variable.mediacommand instead of having to code for each device?
I have created a set of device buttons which tells the hub to switch to that devices controls when selected. I want a single screen of buttons to send the signals for say “exit”, “menu”, “play” etc for the selected device rather than having a different layout for each device.
I have created a virtual device variable that I set to the current device in a trigger when I select the device button as I couldn’t find a system variable.
Some buttons like Volume Up/Down/Mute are explicitly set to the soundbar.mediacommand but I am trying to create a trigger that fires when say “exit” is pressed and send the signal based on the device variable.
Does this make sense?
Thanks in advance for your help.
