Hi. I’m totally new to HR and I hope someone can answer some newbie questions.
For years I’ve been using a Logitech Harmony Elite remote and hub, but sadly it has finally died. I’ve been looking around for an alternative replacement, but I’m dismayed to find there is very little out there to replace the Logitech setup. Indeed, it looks as though similar remotes have all been discontinued.
Then I discovered The Home Remote and I’m excited by its possibilities. I do some programming so hopefully it won’t be beyond my capabilities.
However, since most of my equipment is IR or Bluetooth based, I’m confused as to what I require to work with HR. Any advice will be gratefully received. I have a limited budget, around £100, right now (don’t we all!). Hopefully there’s something available within that price.
Also, is it the IR emitter that has the required codes for controlling the devices, or does all of that come from HR? Assuming the latter, can HR “learn” commands or do we have to rely on requesting unknown remotes are added to HR?
Apologies if this has already been covered. I did a search, but nothing came up that answered my questions.
Thank you in advance of any suggestions.
