Malfunction on tablet android 10
Hello
I just copied my hrp file to an android10 tablet. most of the functions are operational but some image buttons have disappeared or disappear when clicked.
Likewise, the images from my IP cameras are no longer visible. Finally Tuya I have the error message “Tuya Device error NoSuchTarget”
Can you help me?
I specify that everything works correctly on my PC with Home Remote Designer and i have put Trigger on True on my ImgButton
cordially
The Android file system is case-sensitive. Windows is not. If I were to guess, in your XAML your image references are not using the exact casing of the actual images. That would explain why they show in Designer but not the app.
I’m not familiar with that Tuya error. Does it appear randomly? When do you see it? You may have a bad device reference in your project. Does it successfully sync on the app’s Setting page? Go there & do a sync just to make sure it works.
