Hi Folks,
Any ideas what i could be causing the disappearance of the devices browsers under Scenes and Audio Visual when imported on an iOS device?
Screenshots below…
Cheers,
Dan
Hi Folks,
Screenshots below…
Cheers,
Dan
Check your sizes & make sure you assigned the correct Grid.Row & Grid.Column values.
Diligently check your Grid.ColumnSpan & Grid.RowSpans too. If you were to send me your project, I’d say there’s a 75% chance I’ll find you’re trying to access a row or column that does not exist.
In some cases I don’t even know if it makes senses to get all carried away with Grid Columns & Rows. The Grid is pretty powerful even without any Columns & Rows. Margins, HorizontalAlignment, & VerticalAlignment property alone can probably get you what you need.
