Hi,
in MQTT sample (documentation) is used
plugin.PollingInterval = 500;
But inside the onPoll() we are using a
while (true) {...
What will happen here? Will be started the onPoll() again, even if it is running?
In this case here would be a
plugin.PollingInterval = -1;
better - for starting once only.
But if connection to broker is interrupted - the process will not start again…
Or is here any kind of “protection” that no duplicate processes can run?
Then this parameter could realize the reconnects…
(BTW a method “.isConnected” would be great
Thanks!
