Hi. I may be asking the wrong questions or using the wrong terminology (or I’m just being dense), but I can’t find an answers to these questions in the documentation or this forum, so I thought I would try here. Hopefully someone can point me in the right direction.
Is there a function that is run when the HR app starts or is refreshed that can be modified to do whatever is required when the app opens? I want to initialise all of the elements according to what the current state of my AV Amp. For example, I can read which source the Amp is set to, which in turn tells me what other devices should be on, and I want to set the HR to the appropriate display.
I’m used to programming in Javascript where it is possible to create functions to do a set of tasks, even call orher functions. Is there something in HR that can accomplish a similar thing? For example, reset the UI to show everything as ‘off’ and then call a function that would update the UI appropriately. The reset function would be called everytime an option is selected (watch TV, listen to music etc).
I hope that makes sense. I do wonder if I am perhaps thinking about HR correctly. Any advice or pointers would be gratefully received.
Thank you!
