I have different buildings connected via VPN and each one has a different SSID and IP address range. I have different pages in HR to manage each buiding devices and I would like to open HR with the corresponding building page when I move from building to building. Is it possible to do this ? Is there a way to make HR location aware ? Many thanks.
It is not. The Home Remote app doesn’t give you access to GPS location data for your phone. You can submit a feature request for that if you want.
Do you use Home Assistant?
You can setup your buildings as zones in HA, then use the zones (person_name.location) to trigger which page opens.
Jdamore, no, I do not use HA unfortunately…
I thought it would be possible to use the different IP addresses to find out what page to trigger according to the connected WiFi AP address?
