Is it possible to protect our custom designed hrp file with password or pin??
situation( if someone opening our own designed hrp file in home remote designer, ask the password first to open the file)(not in home remote android or ios application)
thanks…
It is not currently possible to password protect the HRP.
could you add the hrp protection feature in the next update??
hopefully…
The HRP is just a ZIP file renamed. Are you wanting to password protect the ZIP file? If so, you would also have to enter the password when opening it with the apps because they will be unable to extract it without.
Or, are you wanting to just add a setting to one of the XML files within the HRP that stores a “Designer Password”? Then when you open the HRP with the Designer, have it prompt you to enter the “Designer Password”. One of the potential issues for you here is that anyone can edit those files outside of the Designer & simply remove that setting. Once they remove it with a simple text editor they could then open it with the Designer.
It doesn’t work yet. I was just wanting to get a better understanding of what you are looking for.
I see. Thanks for the explanation. I’ll try to get something added for you.
Thanks for your time
Hi bill , i hope you’re working on the give request…
