Hi, I migrated from two old Philips bridge to the new Bridge Pro. Now i can`t add the new bridge to THR. Get a pop up problem with the SSL certificate., and can not find any device. Anyone have a solution how to add the bridge pro?
I found a work around. I used Home Assistant as device. Home Assistant support Philips Hue bridge PRO. I simply use the the Home Assistant as hub. Works pefectly in THR. Just some work to change everything and import it into THR.
