PowerSource capability missing from Ring Extender
Greetings.
I have a Ring Extender connected to a Hubitat that I use to determine in the power is on (mains, battery, etc). It does report the PowerSource capability to Hubitat.
But when that device is brought into HomeRemote, the only capability is battery. Am I missing something?
Is the best solution a virtual switch in hubitat that is kept in sync with the Ringextender’s powersource value?
Thanks.
I don’t believe that capability has been handled in the current Hubitat integration. I’ll add it to the next release. For the time being you should be able to add powerSource to the Attributes list on the device object & access it that way.
Thanks Bill, that works just fine that way as well.
Thanks.
BTW, I love this designer. Possibilities are endless. Many thanks!!
