In a case where you might have several Multidata Triggers defined in which under certain conditions you have 2 of the trigger conditions satisfied, which trigger takes precedence, the first trigger that is satisfied (closer to top of list) or the last trigger satisfied (closer to bottom)? (this assumes trigger processing is from top down).
You could test this by making the setters change an obvious property (like TEXT) and see what happens. I made a quick example for you. Play around with the switches. then change the order of the triggers. Ron.hrp (3.9 KB)
The answer is the trigger at the lowest takes precedence
Thanks for taking the time to make the example. I see that what you state is true, the bottom most trigger takes precedence.
