Remote connection HC3
Hi all!
I have a Fibaro HC3 and it’s working fine with Home Remote.
This if I am connected to the same network.
Of course, I setted local IP address in Home Remote - Device - FIbaro so it is the correct behavior.
But, how can I do if I would to connect to my HC3 remotly?
Is it possible?
Thanks!
yes,
you have to to port forward and when you add the HC3 into HR you use the external IP address and port number.
However it does mean that you are opening a port to the HC3. The way i do this is i create a new user account and give access to those devices/scenes that i am using in HR to limit access.
Again it is your own personal risk assessment
