Hello -
I am a little embarrassed by this simple question.
I am trying to control my Panny projector via IP2SL. I have the codes that work in iTest, but cannot figure out how to do this on Home Remote.
As an FYI, I have an IP2IR and an IP2CC working in Home Remote, just cannot get serial to work. For some reason, the command does even make it to the iTach device. per the LED on iTach.
I set up the device as I have set up the prior 2, but need to change the port to 4999. however, when I add the device under 4999, I get a time out error.
In addition, I just want to be sure that my format is correct when creating/adding new Codeset.
For example, I have
POWER_ON,  \x02PON\x03
I am hoping someone can help. I know this has been done before.
Thanks again
