Hello,
Im very new to The Home Remote and need a simple help:
Id like to have an “Plugin” that is simply checking if a certain device is connected to LAN (either via MAC or IP )
Is such a simple “IP/MAC” Checker available pls ?
Thanks a lot
Hello,
Thanks a lot
It would be a simple plugin that does a simple http “Ping” command. However, I am not aware if one exists.
Rather than create a plugin, I chose to just use the Android Tasker program to send the Ping. It is only a couple of lines of code in Tasker.
Hi,
I made exactly such a plugin a few years ago, this was also asked a few weeks ago on the forum. I used to curl command to a website that returns the ip address of the device… I then parsed the first 2 digits (in my case it was 90) for home/away ip address. It worked fine to show IP cameras url. I cant see the hrp in my emails but can probably find the hrp with the plugin if needed.
John
If you cant find it I wil try
John
That would be great, I was not able to find it and also the code as such doesnt help too much as Im really new to The Homeremote - Still Im using it as the interface to my house based automated by Fibaro.
So if you have an plugin I just import ad it will allow me to change the picture of the “tile” based on “IP/MAC” online or offline would be fantastic
Thanks in advance
