Hi
This is my first plugin… not sure about the code quality, but it works!
Basically this lets you send messages over IP to a UK Sky HD box. I use it for direct access to various fast-forward / rewind speeds, but there are many other features.
For the SOAP stuff, you’ll need the UDN of your box which you can get using this tool here… also massive credit to lgladdy for lots of work with this stuff over the years.
… or you could also use this nodered flow …
https://flows.nodered.org/flow/c39095989dc6881bd96b
If you’re not interested in the SOAP stuff and just want the buttons, then you can leave the UDN box blank, and just don’t use the ‘Fwd’ and ‘Rwd’ commands.
I think the remote stuff should also work on Sky Q boxes but don’t have one to confirm. I don’t think the SOAP stuff will work - it’s different, but again, not entirely sure.
Perhaps someone with Sky Q could verify?
Sky_Picasso.plugin (4.4 KB)
but easily worked around if needed I guess
