This is a plugin for a Sony Blu-ray Player that is controlled over IP.
I have a Sony BDP-S3700 and I am not familiar enough with how various kinds of Sony BD players are controlled, so this may only work with a subset, at least without a little modification. I pulled parts of it from these topics on controlling other Sony devices:
- https://groups.google.com/d/topic/thehomeremote/kqSF9h49uxk/discussion
- https://groups.google.com/d/topic/thehomeremote/yha-wJUWubg/discussion
- http://www.remotecentral.com/cgi-bin/mboard/rs232-ip/thread.cgi?171,3
I also included the Wake-on-LAN functionality discussed in one of the topics from the old forum and I added a Select command that wasn’t present in the linked documentation that I got from iRule.
The plugin has 5 settings that can be configured: Host, Port, MAC, UseIPforWOL, and WOLPort. Host should be set to the player’s hostname/IP address and port seems to vary based on the specific model of BD player (50001, 52323, or even 80). MAC is the MAC address of the player. UseIPforWOL, if it is set to anything other than an empty string, will also send the Host and, if specified, WOLPort in the WOL message. My particular player only needs the MAC address, but the WOL API supports the additional information so I included but did not test them.
Last Updated: 2020-04-28
SonyBDPlayer-2020-04-28.plugin (7.2 KB)
plugin.Name = "SonyBDPlayer";
plugin.PollingInterval = -1;
plugin.DefaultSettings = {
"Host" : "192.168.1.1",
"Port" : "50001", // some use 52323 or standard 80 instead
"MAC" : "11:22:33:44:55:66",
"UseIPforWOL" : "", // set this to anything other than empty string if need to send IP (and port) for WOL; host must be IP address and not name in this case
"WOLPort" : "", // standard is 9; if left empty, the port will not be sent
var VERSION = "2020-04-28";
var http = new HTTPClient();
var powerOn = false;
var mediaCommandMappings = {
"PowerOn" : "WOL",
"PowerOff" : "AAAAAwAAHFoAAAAVAw==",
"DirectionUp" : "AAAAAwAAHFoAAAA5Aw==",
"DirectionLeft" : "AAAAAwAAHFoAAAA7Aw==",
"DirectionDown" : "AAAAAwAAHFoAAAA6Aw==",
"DirectionRight": "AAAAAwAAHFoAAAA8Aw==",
"Select" : "AAAAAwAAHFoAAAA9Aw==",
"Home" : "AAAAAwAAHFoAAABCAw==",
"Options" : "AAAAAwAAHFoAAAA/Aw==",
"Return" : "AAAAAwAAHFoAAABDAw==",
"Number1" : "AAAAAwAAHFoAAAAAAw==",
"Number2" : "AAAAAwAAHFoAAAABAw==",
"Number3" : "AAAAAwAAHFoAAAACAw==",
"Number4" : "AAAAAwAAHFoAAAADAw==",
"Number5" : "AAAAAwAAHFoAAAAEAw==",
"Number6" : "AAAAAwAAHFoAAAAFAw==",
"Number7" : "AAAAAwAAHFoAAAAGAw==",
"Number8" : "AAAAAwAAHFoAAAAHAw==",
"Number9" : "AAAAAwAAHFoAAAAIAw==",
"Number0" : "AAAAAwAAHFoAAAAJAw==",
"Display" : "AAAAAwAAHFoAAABBAw==",
"Audio" : "AAAAAwAAHFoAAABkAw==",
"SubTitle" : "AAAAAwAAHFoAAABjAw==",
"Favorites" : "AAAAAwAAHFoAAABeAw==",
"Yellow" : "AAAAAwAAHFoAAABpAw==",
"Blue" : "AAAAAwAAHFoAAABmAw==",
"Red" : "AAAAAwAAHFoAAABnAw==",
"Green" : "AAAAAwAAHFoAAABoAw==",
"Play" : "AAAAAwAAHFoAAAAaAw==",
"Stop" : "AAAAAwAAHFoAAAAYAw==",
"Pause" : "AAAAAwAAHFoAAAAZAw==",
"Rewind" : "AAAAAwAAHFoAAAAbAw==",
"FastForward" : "AAAAAwAAHFoAAAAcAw==",
"Prev" : "AAAAAwAAHFoAAABXAw==",
"Next" : "AAAAAwAAHFoAAABWAw==",
"SkipBackward" : "AAAAAwAAHFoAAAB2Aw==",
"SkipForward" : "AAAAAwAAHFoAAAB1Aw==",
"Angle" : "AAAAAwAAHFoAAABlAw==",
"TopMenu" : "AAAAAwAAHFoAAAAsAw==",
"PopUpMenu" : "AAAAAwAAHFoAAAApAw==",
"Eject" : "AAAAAwAAHFoAAAAWAw==",
"Karaoke" : "AAAAAwAAHFoAAABKAw==",
"Qriocity" : "AAAAAwAAHFoAAABMAw==",
"Netflix" : "AAAAAwAAHFoAAABLAw==",
"Mode3D" : "AAAAAwAAHFoAAABNAw==",
console.log("onChangeRequest called...");
var mac = plugin.Settings["MAC"];
var useipforwol = (plugin.Settings["UseIPforWOL"] == "") ? false : true;
var wolport = plugin.Settings["WOLPort"];
switch(attribute) {
case "MediaCommand":
var cmd = mediaCommandMappings[value];
if(cmd) {
if(cmd == "WOL") {
console.log(" MAC: " + mac);
console.log(" use IP for WOL?: " + useipforwol);
console.log(" Host: " + host);
console.log(" WOLPort: " + wolport);
var wolOpts = {};
if(useipforwol) {
wolOpts["address"] = host;
if(wolport != "") {
wolOpts["port"] = parseInt(wolport);
console.log(" sending WOL to: " + mac + " with " + wolOpts);
WOL.wake(mac, wolOpts);
} else {
console.log(" sending WOL to: " + mac);
WOL.wake(mac);
// very simple power state monitoring
powerOn = true;
} else if(!powerOn && value == "PowerOff") {
// we're not on, so don't try to turn us off (this avoid an annoying message in some situations)
console.log(" not powered on, so power off command ignored");
} else {
var url = "";
var body = "";
var httpOptions = {};
console.log(" Port: " + port);
url += "http://" + host;
if(port != 80) {
url += ":" + port;
// NOTE: some devices apparently use "/sony/IRCC" instead
url += "/upnp/control/IRCC";
body += "<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body><u:X_SendIRCC xmlns:u=\"urn:schemas-sony-com:service:IRCC:1\"><IRCCCode>";
body += cmd;
body += "</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>";
httpOptions = {
headers: {
"Content-Type" : "text/xml",
"SOAPACTION" : "\"urn:schemas-sony-com:service:IRCC:1#X_SendIRCC\"",
console.log(" sending request to: " + url);
console.log(" command: " + cmd);
http.post(url, body, httpOptions);
if(value == "PowerOff") {
// update power state
powerOn = false;
// all done
} else {
console.log("ERROR: unsupported command: " + value);
break;
default:
console.log("ERROR: unsupported attribute type: " + attribute);
break;
console.log("onConnect called...");
if(device) {
console.log(" setting supported media commands...");
device.SupportedMediaCommands = Object.keys(mediaCommandMappings);
console.log(" set...");
function onDisconnect() {
console.log("onDisconnect called...");
console.log("onPoll called...");
console.log("onSynchronizeDevices called...");
var device = new Device();
device.Name = plugin.Name; // override default naming conversion so it looks nicer
device.Id = plugin.Name;
device.DisplayName = "Sony BD Player";
device.Icon = "Disc";
device.Capabilities = [ "MediaControl" ];
device.Attributes = [ ];
console.log(" done syncing");
so I don’t do much with THR at the moment. Hoping to build a new one in my new house, but that may take a while. I also am very rusty on the iRule terminology, so I’m afraid I can’t even help with that level of translation. That said, once you get the hang of how THR does things, it’s pretty powerful and intuitive–getting started is definitely the tricky part.
