Hi
Got a bit of a weird issue. I’ve got one computer where I simply cannot use the TCPClient. The connect function fails:-
socket.connect(plugin.Settings["Host"], parseInt(plugin.Settings["Port"]));
results in:- ‘No public methods with the specified arguments were found.’
The plugin settings are valid, and the same problem happens even if I hardcode IP and port in there.
This same HRP file works fine on another machine. Even the example code from here fails:- TCP Client | The Home Remote
At a loss as to what this could be - any ideas?
