I have been tweaking the Runco plugin with commands for my Epson Projector, and I’m at a point that I want to see if the commands work. I have my Global Cache 100-12 already set up in the devices area of the home remote, and I assumed I would right-click the GC-100-12 and then select “add plugin”. However, it installs the plugin in the top level of the devices menu instead of inside of the Global Cache device. As a result, I’m not sure how to direct the data to the correct port on the GC-100-12 (in my case, the serial port 2:1). If I simply try to directly add a device the dropdown menu doesn’t give me an option for choosing a serial port–only IR ports or relays.
What is the proper way to install the plugin where it directs communication through the GC-100? Thanks!
I’ll post here in case it comes in handy for anyone else.
