VeraSecure Linear GD00Z-05 Device Import
Though I have started playing with the designer, this question is strictly for the stock Android app V3.10.2.0. I have been playing with the app for a couple months without much issue (questions… yes), but the burning question is that I just added the Linear GD00Z-05 into my VeraSecure along with an addition light switch. Only the switch got synchronized. The GD00Z-05 “Garage Door” is never brought in. Is this something silly I am overlooking? I have rebooted the Vera, rebooted the Android device, and re-ran the sync multiple times. This noob would appreciate any help or advise. Thanks
Vera connected garage door devices aren’t currently supported. I can add support for them but I’ll need to know exactly which commands they use for Open/Close as well as the shortcode they use in the sdata.
If you could, would you mind emailing me the JSON from these 2 requests?
http://192.168.1.108:3480/data_request?id=user_data2
http://192.168.1.108:3480/data_request?id=sdata
I’m thinking they probably use these standard switch on/off commands but the JSON in “user_data2” will tell me for sure.
http://192.168.1.108:3480/data_request?id=action&output_format=json&DeviceNum=67&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=1
http://192.168.1.108:3480/data_request?id=action&output_format=json&DeviceNum=67&serviceId=urn:upnp-org:serviceId:SwitchPower1&action=SetTarget&newTargetValue=0
For status, I’m thinking they probably use a “status” shortcode that will be 0 for closed & 1 for open.
Thank you soooo much for the expedient and direct response. I am pretty new to all this and not very familiar with JSON. That being said, I was able to pull the two JSON files you asked for. I assume I just upload them here and there is nothing in those files that wouldn’t be ok for public consumption…??.. but .json is not supported. Do I have the correct files and just need to alter the extension to say .txt so the upload file type is supported?
Send them to me over email at support@thehomeremote.com The file extension doesn’t really make a difference. They can be either TXT or JSON.
